Clear KHI Statistics
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Chassis.
  3. Select the CPP Stats Control tab.
  4. Select the statistics you want to clear.
  5. Select Apply.
CPP Stats Control Field Descriptions
Use the data in the following table to use the CPP Stats Control tab.
Name
Description
PortStatsClear
Clears port statistics.
